Percent Complete Type
Percent Complete Type field
Determines the way in which the application calculates the percent complete for the activity.
The type can be Units, Duration, Physical, or Scope. If the Percent Complete Type is Units, percent complete is calculated from the actual and remaining units. If the Percent Complete Type is Duration, the percent complete is calculated from the actual and remaining duration. If the Percent Complete Type is Physical, the user will enter the percent complete for the activity. If the Percent Complete Type is Scope, the percent complete is calculated by Oracle Primavera Cloud and cannot be modified in P6.
