Price/Unit (Assignments)
Price/Unit field
The non-overtime price per unit of time for the resource or role.
When the option to Calculate Costs from Units is selected, this price is used to compute costs for the activity assignment, using the formula: Cost equals Units multiplied by Price divided by Unit.
For resources and roles that have specified rates, Price/Unit corresponds to the Rate Source and Rate Type applied to the activity and is not editable. If an assigned resource or role does not have specified rates, the project default price/unit is used and cannot be edited on this tab. To manually enter a Price/Unit for the activity assignment, you must select Override as the Rate Source.
If the project default price/unit is applied to the activity, a caret symbol (^) appears beside the value. An asterisk symbol (*) beside the value indicates that multiple, time-varying, resource rates or shift calendars will be applied during the duration of the activity. An asterisk and caret symbol (*^) beside the price/unit value indicate that the project default price/unit is in effect at the start of the activity and a time-varying rate is also in effect within the activity assignment duration.
