Publishing P6 Global Data On Demand
You can publish any of the following types of global data to the reporting tables on demand.
- Enterprise Data
- Project Data
- Activity Data
- Resource Data
- Calendar Data
- Enterprise Data dictionary definitions
- Enterprise Summary Data including portfolio data
- Resource Management Data
- Security Data
- Audit Data
To publish P6 global data on demand:
- On the
Navigation Menu, expand
Administration and click Scheduled Services. - On the Scheduled Services page, select Global.
- On the Global page:
- Select a global service.
- Click Run Service.
- In the resulting message box, click OK.
Tip:
- If the service listed under the manually selected service is configured to run After previous service, it will run automatically when the selected service finishes.
- You must have the Administer Global Scheduled Services global security privilege to run a global scheduled service.
