Range (Risk Thresholds)
Range field
The user-defined range for each threshold level where the breadth of the range specifies the amount of risk associated with the assigned level.
You can enter text or numeric data in this field depending on the threshold type.
Probability: The value is a percentage.
Tolerance: The value is a number.
Cost Impact by value: The value is the cost.
Schedule Impact by value: The value is a duration.
Cost Impact by percentage: The value is a percentage.
Schedule Impact by percentage: The value is a percentage.
User-defined Impact: The value is text.
