Resources Navigation Bar
Overview
Click an icon on the Resources Navigation Bar to open its corresponding page.
Screen Elements
Administration
Enables you to configure resources, resource teams, roles, and role teams.
Planning
Enables you to specify, review, or modify project-level and WBS-level allocation data for individual resources and roles across a project's life cycle.
Assignments
Enables you to view and configure resource assignment data in a variety of formats: Gantt chart, table, or usage spreadsheet.
Analysis
Enables you to evaluate resource and role usage and costs with a spreadsheet or histogram. You can view resource analyses in customizable histogram, stacked histogram, area chart, and pie chart formats.
