Resource Type
Resource Type field
The type of resource/role assignment.
Valid values are:
Labor: Indicates that the selected resource performs labor, which is measured in units of time.
Nonlabor: Indicates that the selected resource does not perform labor, but its work is measured in units of time.
Material: Indicates that the selected resource does not perform labor, and its work is measured in units you specify.
