Setting Work Hours Per Time Period for My Calendar
Configure the work hours per time period settings to specify the default number of hours in a work period for a calendar. The values you specify here are used as conversation factors when displaying time units in increments other than hours. Any resource-dependent activity that uses this resource calendar will use these values as conversion factors for these activities.
To use this feature, the Use assigned calendar to specify the number of work hours for each time period option must be selected in on the Time Periods page in Application Settings.
To set the number of work hours for each time period:
- Click the User menu and select My Calendar.
- On the My Calendar page, select the Summary tab.
- On the Summary tab, in the Time Periods area, enter an hour value in each field.
- Click Save.
