Sharing Your Feedback With Us
From time to time, we will open a feedback survey through which you can share your feedback about working with P6 EPPM. When you log in, you'll see a dialog box asking you to Help Us Improve. You can either take the survey at that time, or you can request to be reminded later. Alternatively, you can choose to participate in the feedback survey at a time more convenient to you, by opening the feedback survey from the User menu.
To open the feedback survey:
  1. Click the User menu and select Share Your Feedback.
