Step Weight
Step Weight field
The weight assigned to the step.
Step weight indicates the step's importance to the activity. The higher the value, the greater the importance. Step weight is used to calculate Physical Percent Complete and Activity Percent Complete.
If you do not enter a step weight, the application assigns the step a default weight of one.
