Total Units
Total Units field
Project or WBS: The total number of units rolled up from assignments in the project or WBS.
Resource: The total number of units allocated to the resource.
Role: The total number of units allocated to the role.
The units are displayed in the Time Units Format you selected in your user preferences.
