Unlocking Your Account
If you forget your P6 password and exceed the number of attempts allowed to log in, the system will lock your account.
You can request a reset code that will be emailed to the account associated with your P6 user. After your account is unlocked, P6 will prompt you to change your password.
To unlock your account:
- On the login screen, click the Unlock Account/Forgot Password link.
- In the Unlock Account and Reset Password dialog box:
- In the Username field, type your username.
- Click Next.
- Check your email for the one-time code.
- In the One Time Code field, type the one-time code you received.
- Click Next.
- In the Password field, type a new password.
- In the Confirm Password field, re-type the new password.
- Click Save, then click Close.
- Even if your account has not yet been locked, you can follow these steps to reset your password using the Forgot Password? link on the login page.
- Check your email's spam folder if you do not receive the one-time code.
- You cannot change passwords if P6 EPPM is running in LDAP or SSO authentication mode. If you are unable to unlock your account, contact your system administrator.
