Updating Projects With Data From Oracle Primavera Cloud
You can update a linked P6 project with data from Oracle Primavera Cloud.
To update projects with risk data from Oracle Primavera Cloud:
  1. On the "" Navigation Menu, expand "" Projects and click Activities.
  2. In the Activities page click the Actions"" menu and select Exchange Data and then select the menu option for updating data from Oracle Primavera Cloud.
