Updating the Progress of Activities Using P6
Update status to define percent complete and start and finish dates.
To update status:
- On the
Navigation Menu, expand
Projects and click Activities.
Tip:
- You can update the progress for resources working on an activity on the Assignments detail window.
- You can also update units, costs and other fields for an activity in the activity grid if you add the relevant columns to the grid.
