Viewing Audit Data
If you have configured table auditing in your database, changes to any tables you are auditing are recorded in real time. You can view the audit data by using the audit panel on the EPS page of P6.
To view audit data in P6:
- On the
Navigation Menu, expand
Projects and click EPS. - Select the projects or grouping nodes for which you want to view audit data, then click
Context menu and select View Audit Data. - In the Audit panel you can:
- Use the Subject Area menu, to select the tables for which you want to view data.
- Use the Date menu, From field and To field to limit the data shown to a specific time period.
Click
Customize View to configure the columns you want to view, filter your view further, or determine the sort order to use in the panel.
- Print the data.
- Drag the edge of the panel to make it wider or narrower as needed.
