Viewing Relationships with Trace Logic
Use trace logic to follow activity relationships throughout a project.
To view relationships with trace logic:
  1. On the "" Navigation Menu, expand "" Projects and click Activities.
  2. On the Activities page, select an activity and click the Trace Logic detail window.
  3. In the Trace Logic detail window:
    1. The selected activity is shown with its predecessor and successor activities.
    2. Click another activity in the detail window to see its connections to predecessor and successor activities.
Tip:
  • Click the top edge of the Trace Logic detail window and drag upward to make the window larger.
  • You can click and drag the detail window contents.
