WBS Path
WBS Path field
A series of WBS codes that represent the position of the WBS within the project hierarchy.
For example, if you have a parent WBS named WBS1, a child named WBS2, and WBS2 has a child called WBS3, the WBS Path for WBS3 is WBS1.WBS2.WBS3.
