Working With Oracle Primavera Cloud
You can send data to Oracle Primavera Cloud to:
  • Manage scope using data sent from P6.
  • Perform quantitative analysis of enterprise risks data sent from P6 then bring data about the results of that analysis into your P6 schedule to see pre and post response pessimistic dates and show pre and post response bars for activities.
  • Take advantage of the risk, scope, tasks, and portfolio functionality in Oracle Primavera Cloud while leveraging the execution data from P6.
Sharing data with Oracle Primavera Cloud using Primavera Gateway
If P6 EPPM is integrated with Oracle Primavera Cloud using Primavera Gateway or a P6 connection in Oracle Primavera Cloud, you can control when you send data to Oracle Primavera Cloud. The data you send to Oracle Primavera Cloud can be manipulated in Oracle Primavera Cloud and then imported back into P6 EPPM.
To integrate P6 with Oracle Primavera Cloud, you should ask your Primavera Gateway administrator to configure the necessary flows.
For further information about configuring integration between P6 and Oracle Primavera Cloud see Working With Primavera GatewayWorking With Primavera Gateway.
