Working With Oracle Primavera Cloud Tasks
You can view public tasks associated with activities from the Oracle Primavera Cloud Tasks app in P6. Tasks are visible in P6 on the Tasks detail tab in an integrated project. In the Activities page, you can easily see which activities have tasks assigned to them and can identify activities with tasks that are all completed or that have dates outside of the activity dates by adding these columns to the Activities grid: Task Status - Dates, Task Status - Completion, and Task Status - Indicator.
You can also view quantitative risk analysis data associated with the activities from the Oracle Primavera Cloud Risks app in P6. In the Activities page, you can see which activities were part of the critical path during risk analysis in Oracle Primavera Cloud and how often those activities were on the path in the Pre-Response Criticality Index and Post-Response Criticality Index columns. In the EPS page, you can view the Pre-Response Pessimistic Start Date, Pre-Response Pessimistic Finish Date, Post-Response Pessimistic Start Date, and Post-Response Pessimistic Finish Date fields calculated in Oracle Primavera Cloud during quantitative risk analysis.
Tip:
  • If you change the Activity ID of an activity in P6 which is linked with Oracle Primavera Cloud Tasks, the ID will be overwritten with the Activity ID which exists in Oracle Primavera Cloud Tasks the next time data is imported.
  • By default, activities which exist in the P6 project but not in the integrated Oracle Primavera Cloud project are removed when the Send Primavera Cloud project data to P6 for Task (formerly Send Primavera Cloud project data to P6 for Lean Task) flow is activated in Primavera Gateway. Your Primavera Gateway administrator can change this behavior.
  • If Oracle Primavera Cloud and P6 are integrated via Oracle Primavera Cloud workspace instead of using Primavera Gateway, activities which exist in the P6 project but not in the integrated Oracle Primavera Cloud project are always removed when the Send Primavera Cloud project data to P6 for Task flow is activated.
