Editing the Primavera Portfolio Management Branding Strip
To edit the Primavera Portfolio Management branding strip:
- Click Edit. The Branding Strip-Primavera Portfolio Management dialog box appears.
- Select the branding Strip Type:
- Default-- uses system defaults for the branding strip.
Custom-select this option to access the following Custom Settings:
Branding Image URL-enter the URL for the location of the branding image GIF.
Hover Text-enter the text you would like to have appear when hovering over the strip.
Hyperlinked Web Site-enter the URL of the web site that will open when the user clicks on the strip.
Background Color-the color can be either Solid or Gradient. If the gradient option is selected, you can enter the values for the two colors that will form the gradient.
- Click OK to save your parameters.
