Versions
This section describes how to create a new version using the New Version Wizard.
When any field or component in the system is pre-configured with a version, that field or component will always be displayed with the Data as of that version, and will not change as a result of the end-user selecting a different version in the Select a Version popup. The background of these fields and components will be the regular background color. Only areas showing versioned data as a result of the end-user selecting a version in the Select a Version popup are colored using a standard neutral peach color. It is not possible to change this color or to assign different background colors to different versions.
