Changing an Expected Item from a Submittal to a Closeout or from a Closeout to a Submittal
When logged into Submittal Exchange, select a project and go to the Sections & Categories tab.
- Select the section that requires adjustment to the submittals or closeouts. This section number and name are highlighted in blue.
- Below the box to the right, select Edit.
- Using the drop-down list to the left of the Item Description, change Submittal to Closeout or Closeout to Submittal as necessary.
- Select Save.
- Repeat as needed.
