Moving a Submittal to Another Section
When logged into Submittal Exchange, select a project and go to the appropriate log.
- Select the submittal that must be moved. (Anything but the file.) A dialog box appears.
- Select Edit Detail in the top right corner. The dialog box changes.
- Select Move section in the top right corner. The dialog box changes.
- Use the Move to log field to select the log to which the item should move.
- Use the Move to Section field to select a section.
- Select the section under which the item should move.
- Select Save.
The submittal is now moved to the new section.
If section sequential numbering is used, the submittal number will adjust to reflect the new section number.
