Navigating Submittal Exchange Project Logs
The top of each log has options you can use to customize your view.
Not all users will see all menus, tabs, or options. Access to some features depends on which role or team you are on.Tip:
An alert message is displayed if the log display contains hidden columns. Select the Table Settings icon within the alert to show hidden columns and to hide additional columns.
