2 Run Built-In Report
To run a built-in report:
- From the Reports page, expand the built-In node if not already expanded.
- Select a report and select the Run Report button. Or, select a report and choose Run Report from the Gear
icon. You can also double-click to run the report.
Tip:
- To filter and search for a specific report, use the Search box or the in-column filters.
- To share this report, from the left pane under Output, select the option Send as attachment link.
- To view the report using Document Viewer, use the Output option View Online.
