26 Activity Manager
Unifier enables you to create, consolidate, and monitor activities that must be completed on a schedule by way of the Activity Manager.
Unifier also enables you to set a series of rate rules that should be applied when certain conditions are met in a project by way of the Master Rate Sheet.
Activity Manager Module
To access the module:
  1. Go to the shell tab, and switch to User mode.
  2. In the left Navigator, select Activity Manager.
For details about the Activity Manager, Rate Sheet, and Master Rate Sheet, see the Primavera Unifier Managers User Guide.
