52 Configuration Package Management
If you have the required permission, you can manage the Configuration Package creation and import through the Configuration Package Management grouping node in the left Navigator. For more information about permissions, see Accessing the Configuration Package Management Node.
The Configuration Package Management grouping node lets you:
- Review the existing items in the Component Lists.
- Create a Component List.
- Review the add-on Component Lists.
- Create an add-on Component List.
- Review the existing Configuration Packages.
- Create a Configuration Package.
- Import a complete Configuration Package.
- Import specific designs from a Configuration Package to a non-production environment.
- Review the add-on Configuration Packages, if permitted.
You can also view changes that have been, or might be, made as part of importing or exporting a Configuration Package. For example, you can compare BP designs included in the Configuration Package to the most recent versions deployed in the environment. For more information, see Comparing Configuration Packages and Viewing Design References.
The following topics provide more information about the Configuration Package Management grouping node and its functional nodes.
