Create or Edit Combo Charts for Visualizations in Projects/Shells
To create or edit Combo charts for visualizations in a project/shell (Admin mode):
- Sign in to Unifier with project/shell administration credentials.
- Go to the specific project/shell tab, and switch to Admin mode. For example, select a tab called Vision Corporation.
- In the left Navigator, select Setup, and then select Visualizations.
- In the Visualizations log (right pane), select any of the following actions:
- Select Create to add a new visualization in the project/shell, and then proceed to step 6.
- To edit an existing visualization, select the visualization in the log, select Edit, and then proceed to step 5.
- On the Edit page, select Edit (
)for a Combo chart in the visualization layout. Proceed to step 6b. - On the Create or Edit page, specify or update the following information:
- After making all changes, perform any of the following actions:
- If you created a Combo chart, select Create, and return to the Edit page.
- To confirm all the changes made to the edited Combo chart, select Update, and return to the Edit page.
- On the Edit page, select Save to update the visualization with any created or edited content.
