Create or Edit Pivot Grids for Visualizations in Projects/Shells
To create or edit Pivot grids for visualizations in a project/shell (Admin mode):
  1. Sign in to Unifier with project/shell administration credentials.
  2. Go to the specific project/shell tab, and switch to Admin mode. For example, select a tab called Vision Corporation.
  3. In the left Navigator, select Setup, and then select Visualizations.
  4. In the Visualizations log (right pane), select any of the following actions:
    • Select Create to add a new visualization in the project/shell. Proceed to step 6.
    • Select a visualization in the log, and then select Edit. Proceed to step 5.
  5. On the Edit page, select Edit ("")for a Pivot grid in the visualization layout. Proceed to step 6b.
  6. On the Create or Edit page, specify or update the following information:
    1. To preview the data before creating the chart:
      1. From the Data Source list, select the data source to use for creating the content item. The list shows published content in the alphabetical order.
      2. From the Preview Project list, select an active project/shell and then click Preview Data.
    2. From the View Type list, select Pivot Grid.
    3. In the Name field, enter a name for the Pivot grid.
    4. (Optional) In the Description field, enter a short description about the Pivot grid.
    5. From the Value list, select a data element from the data source selected above. Displays Count by default.
      For the selected data element in the Value list, select any of the following measures:
      • Average: The mean of all values of the selected data element.
      • Count: (Default) The total number of rows of the selected data element.
      • Max: For numeric fields, displays the highest value. For date fields, displays the maximum date.
      • Median: The central value among all values of the selected data element.
      • Min: For numeric fields, displays the lowest value of the selected data element. For date fields, displays the minimum date.
      • Sum: Sum of all values of the selected data element.
    6. From the Columns list, select a data element to create columns for the Pivot grid.
    7. (Optional) To include additional column tiers in the Pivot grid, click Add Columns.
    8. From the Rows list, select a data element to create rows for the Pivot grid.
    9. (Optional) Click Add Rows to include additional row tiers in the Pivot grid.
    10. (Optional) In the Show Totals field, toggle to show or hide the column totals in the grid.
    11. To visually highlight specific fields in the Pivot Grid, Configure and Manage Conditional Formatting of Tables and Pivot Grids.
    12. Make changes as needed to refine the above selections.
  7. After making all changes, perform any of the following actions:
    • If you created a Pivot grid, select Create, and return to the Edit page.
    • To confirm all the changes made to the edited grid, select Update, and return to the Edit page.
  8. On the Edit page, select Save to update the visualization with any created or edited content.
