Create or Edit Tables for Visualizations in Projects/Shells
To create or edit tables for visualizations in a project/shell (Admin mode):
- Sign in to Unifier with project/shell administration credentials.
- Go to the specific project/shell tab, and switch to Admin mode. For example, select a tab called Vision Corporation.
- In the left Navigator, select Setup, and then select Visualizations.
- In the Visualizations log (right pane), select any of the following actions:
- Select Create to add a new visualization in the project/shell. Proceed to step 6.
- Select a visualization in the log, and then select Edit. Proceed to step 5.
- On the Edit page, select Edit (
)for a table in the visualization layout. Proceed to step 6b. - On the Create or Edit page, specify or update the following information:
- After making all changes, perform any of the following actions:
- If you created a table, select Create, and return to the Edit page.
- To confirm all the changes made to the edited table, select Update, and return to the Edit page.
- On the Edit page, select Save to update the visualization with any created or edited content.
