Create or Update Area Charts, Bar Charts, and Line Charts
To create Area Charts, Bar Charts, and Line Charts for visualizations:
- Sign in to Unifier with company administration credentials.
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select Visualizations, and then select Content.
- In the Content log (right pane), select Create.
- On the Create page, specify the following information:
- To preview the data before creating the chart:
- From the Data Source list, select the data source to use for creating the content item. The list shows published content in the alphabetical order.
- From the Preview Project list, select an active project/shell, and then select Preview Data.
- From the View Type list, select Area Chart, Bar Chart, or Line Chart.
- In the Name field, enter a name for the chart.
- Optional: In the Description field, enter a short description about the chart.
- From the Value list, select a data element from the selected data source. Displays Count by default.
For the selected data element in the Value list, select any of the following measures:
- Average: The mean of all values of the selected data element.
- Count: (Default for non-numeric data elements) The total number of rows of the selected data element.
- Max: For numeric fields, displays the highest value. For date fields, displays the maximum date.
- Median: The central value among all values of the selected data element.
- Min: For numeric fields, displays the lowest value of the selected data element. This measure is not applicable to date fields.
- Percentage: A percent of the filtered value from the total of the selected data element.
- Sum: Sum of all values of the selected data element.
- After populating the required fields for a Bar chart, Area chart, or Line chart, you can allow your users to explore related data using dynamic content by selecting More Actions … and then selecting Configure Drill down.
For more information, see Configure Drill-down Content for View Types.
- Optional: From the Color By list, select a non-numeric data element to differentiate using a color-code. Perform any of the following actions:
- To color-code additional data elements, select Add Color By.
- To remove a color code and the associated data element, select Delete (x).
- If you have selected more than one color code, select Drag
to reorder the color codes.
- From the Category list, select a non-numeric data element that you can use as a category to differentiate the bars in the chart. Perform any of the following actions:
- To select a data element for the category, select Add Category.
- To remove a category and the associated data element, select Delete (x).
- If you have selected more than one category, select Drag
to reorder the categories.
- From the Data Labels list, select the location for displaying labels on the chart.
Common options are:
- Auto: The default data label display setting for all types of charts.
- Center: The data label displays in the center of an Area chart, Bar chart, or Line chart.
- None: The data labels do not display in the chart.
For Area charts and Line charts, the following additional options display:
- Above Marker: The data label displays above the marker point.
- Below Marker: The data label displays below the marker point.
- Before Marker: The data label displays before the marker point.
- After Marker: The data label displays after the marker point.
For Bar charts, the following additional options display:
- Inside Bar Edge: The data label displays on the inside edge in a Bar chart.
- Outside Bar Edge: The data label displays on the outside edge in a Bar chart.
- From the Orientation list, select the orientation as either Horizontal or Vertical (default).
- In the Stacked field, select whether to show or hide a stacked Bar chart.
- In the Show Value Total field, select whether to show or hide the total for each segment in a stacked Bar chart.
- In the Show Category Axis Title field, select whether to show or hide the label of the data element that you selected for the X-axis.
- In the Show Value Axis Title field, select whether to show or hide the label of the data element that you selected for the Y-axis.
- Make changes as needed to refine your selections.
- After making all changes, perform any of the following actions:
- To save the chart in a Draft status, select Create Draft, and return to the Content log.
- To save additional changes made to an existing chart in Draft status, select Update Draft.
- To delete the chart, select Cancel. You will lose all unsaved changes made to the chart.
- To make the chart available to your users for data visualizations, select Publish, and return to the Content log.
