Create Visualizations in Projects/Shells
Project/Shell Administrators can create and edit visualizations in projects/shells they have access to. The visualizations can be created using the default content items made available to you by your Company Administrators. Apart from the default content, Project/Shell administrators can also create content in projects/shells. See Create or Edit Visualization Content Items in Projects/Shells.
To create visualizations in a project/shell (Admin mode):
- Sign in to Unifier with project/shell administration credentials.
- Go to the specific project/shell tab, and switch to Admin mode. For example, select a tab called Vision Corporation.
- In the left Navigator, select Setup, and then select Visualizations.
- In the Visualizations log (right pane), select Create.
- In the Create Visualization drawer, enter the following information:
- In the Choose layout to start drawer, select a layout for the visualization. Options include:
- 1-panel collection
- 2-panel hero visualization
- 2-panel side-by-side
- 2-panel vertical collection
- 3-panel auto fit
- 3-panel collection
- 5-panel collection
- In the selected blank layout page, select Library.
- In the Library drawer, select the Content tab.
- The name of the content item.
- The type of content, such as a KPI card, Bar chart, and so on.
- The data source used for creating the content item.
The published status can be any of the following:
- Synced: Indicates the published content item is in sync with the saved version.
- Local: Indicates the content item has been newly created and is available only in this project/shell.
- Select a content item, and then select and drag the item onto a block in the visualization layout. Repeat to populate all blocks in the layout. For example, select and drag a stacked Bar chart to the layout.
- (Optional) If you want to create content items for the visualization, select Create. See Create or Edit Visualization Content Items in Projects/Shells.
- Perform any of the following actions in any order:
- In the Search bar, locate a content item by name, data source, view type (such as a Bar chart, Area chart, and so on), or published status.
To refresh the list of displayed content items, select Refresh (
- To change the visualization layout, select the Layout tab.
- Make changes as needed to refine the above selections.
- To add visualization in additional tabs, select Add new tab (+), adjacent to the Default or a renamed tab.
- Repeat the above steps for each tab. You can:
- Add, remove, or update a maximum of 15 tabs with layout and content,
- Select a different layout in each tab.
- Drag and reorder the tab sequence.
- Set up independent filters for each tab.
- Select Save to save changes across all tabs.
- After populating the tabs and visualizations, select Create, and return to the Visualizations log.
