Creating Partner Companies, Users, and Permission Settings (On-Premises Only)
A Company Administrator of an Owner Company (Sponsor Company) can create multiple partner companies.
To create partner companies, complete the steps outlined in Adding a Partner Company.
The Partner Users node contains multiple menu options that you can use to perform steps such as creating new users manually or through import or updating types. The toolbar options provide access to some of the same features as well as providing quick access to changing the Status of a user account.
The Update User Type (To Portal and To Standard) option, collectively, work as a bulk action on one or more selected user rows by enabling you to update the type of user. For example, you can select one row, or multiple rows, select Update User Type, and change the user type to portal, or standard, by selecting To Portal, or To Standard.
Creating Users for the Partner Company
To add users to a Partner Company:
  1. Go to the Company Workspace tab, and switch to Admin mode.
  2. In the left Navigator, select User Administration, and then select Partner Users.
  3. From the toolbar, select New, and then select Manual.
  4. In the Edit User dialog box, enter data in the fields within each tab.
    • General
      1. Enter the name of the Partner Company (the system conducts a search and displays a filtered list of partner companies).
      2. Alternatively, you (Company Administrator) can select the name of the Partner Company from the list by selecting the arrow.
      3. Fill out the fields under "Contact Information as in Company Directory."
      4. Select the Status, and select OK.
    • Security: To enter the password for the user.
    • Groups: To add the user to an existing group.
    • Permissions: To assign permissions to various modules in the system.
    • Projects/Shells: The content in this tab is blank when creating a user, and any existing content varies based on the Projects/Shells that the user has access to.
    • Proxy: To manage Proxy settings.
If the user type attribute is not mentioned when creating the user, the user type for that user will be set to Standard user type by default.
When you are creating a user, the User Type drop-down list is defaulted to Standard user, but you can change the User type to Portal.
The Attribute "Earned Value Management" displayed is unchecked by default. If the user checks this option, the user will be granted access to the Earned Value Management module. This checkbox will be disabled for Portal type of users. The licensing purchased by your organization determines whether EVM is included.
The checkbox for Earned Value Management users will be seen only when the Earned Value Management module is loaded.
In the License Manager, the Company user and Partner user are considered Standard users in terms of license count and combined count for License Terms and Current Usage. The License Manager landing page will define a gauge chart for all the following license types, which varies depending on the licensing purchased by your organization:
  • Standard Users
  • Portal Users
  • Earned Value Management Users
  • Collaborator Users
Separate counts for Portal users and Earned Value Management (EVM) users are shown for License Terms and Current Usage. These counts will depend on:
  • The licensing purchased by your organization,
  • Whether a particular Company user is marked as Portal user, and
  • The Earned Value Management user in User Administration.
The current ‘Primavera Unifier – Application User Perpetual’ license supports unlimited portal users.
If there are more users with accounts than the product is licensed for, the calculations in the Active Named Users fields might be higher in the Current Usage sections versus the License Terms sections. The excess or surplus (overage) is calculated in the same way as the Standard users.
The Site Administrator can edit the license terms and view the audit log for the users by selecting Settings.
When editing the user count, the Site Administrator will have to put a combined number for active named users.
Depending on the licensing purchased by your organization, the Site Administrator will also be able to edit the Portal users and EVM users count by using the General and Notifications tabs on the License Terms window.
For users other than the Site Administrator, only the Notifications tab will be available to be edited.
Permission Settings for Partner Companies
To set permissions for partner companies:
  2. In the left Navigator, select User Administration, and then select Access Control.
  3. In the right pane, expand Administration Mode Access, expand User Administration, and then select Partner Companies.
  4. In the Module Permission Settings window, determine the level of permission for each user (in the Partner Company) that is listed.
    You can select Add (to add a new name), Modify (to change the permission setting for a user, by way of Permission/Access Control window), or Remove (to delete a name) in this window.
If you (Company Administrator) create a Partner Company and select Inactive for the Partner Company Status, the users that you add for that Partner Company will be inactive. When the contract with a Partner Company ends, you can select Inactive for the Partner Company Status and inactivate the contract.
