E-Signature Audit Log
If you have at least view permission for Acrobat Sign or DocuSign, you can view updates to the e-signature type in the audit log.
To access the E-signature Audit Log:
- Go to the Company Workspace tab, and switch to Admin mode.
- In the left Navigator, select Integrations, and then select Acrobat Sign/DocuSign.
- From the More Actions
menu, select Audit Log.- The total number of audit log entries.
- Date: Date on which the information was modified. Date format displays based on your user preferences.
- Name: Name of the project or template.
- Action: Type of action performed. Displays Modified.
- Old Value: The old value of the field. Displays DocuSign, Acrobat Sign, or Default.
- New Value: The new value of the field. Displays DocuSign, Acrobat Sign, or Default.
- User Name: The name of the logged in user.
- Proxy User: The name of the proxy user.
- Perform any of the following actions:
- In the Search bar, specify your filter criteria to focus on a subset of audit log entries.
To download the log in Excel format, select Download (
