Edit Visualization Properties
Project/Shell Administrators can edit visualizations from the Visualizations log of projects/shells they have access to.
You must have the Manage permission enabled for visualizations in the specific project/shell to perform this task.
To edit visualizations from the Visualizations log of a project/shell:
  1. Sign in to Unifier with project/shell administration credentials.
  2. Go to the specific project/shell tab and switch to Admin mode. For example, select a tab called Vision Corporation.
  3. In the left Navigator, select Setup, and then select Visualizations.
  4. In the Visualizations log (right pane), from the Action "" menu, select Edit Properties for a visualization.
  5. In the Edit Properties drawer, edit the following information for the selected visualization:
    • Name: Name of the visualization. For example, a visualization called RFI Summary.
    • Description: (Optional) A short description of the visualization.
    • Location: (Optional) The location of the visualization in the left Navigator. For example, select Document Issues to display the Visualizations node under the Document Issues business process (BP) in the User mode.
      (Default) If a location is not specified, the visualization displays in the Visualization log of the project/shell in the User mode.
    • From the Data Rollup list, select one of the following:
      • Current Shell Only (Default): Includes data from the current project or shell only.
      • Current Shell and Sub Shells: Includes data from the current shell and its sub shells.
      • Sub Shells Only: Includes data from the sub shells and excludes the current shell.
      • Query-based Shells: Includes data only from projects or shells that satisfy the configured query conditions. For more information, see Configure Query-Based Rollup for a Visualization.
  6. Perform one of the following actions:
    • To save your changes, select Update.
    • To discard your changes and return to the Visualizations log, select Cancel.
