Enable View Permission For Visualizations in User Mode
Company Administrators can set up view permission to access visualizations for users and groups in the User mode.
To set view permissions to access visualizations in the User mode:
- Sign in to Unifier with company administration credentials.
- Go to the Company Workspace tab, and switch to Admin mode.
- In the left Navigator, select User Administration, and then select Access Control.
- In the Access Control log (right pane), expand User Mode Access and select the Visualizations node.
- In the Permissions Settings for: Visualizations dialog box, select Add.
- Select OK.
