Filters: (Optional) Create Filters for Data Elements
You can set up filters to display only those data elements that meet the filter criteria in the data source being created. For example, you can create a filter to display only those records with an Open Issue Status.
This step is optional. You can select Skip to move to Preview: Created Data Source of the guided process.
To create a filter on a data element:
