Integration Users
An integration user is a user that performs integrations using REST services.
New integration users are configured to use Basic integration by default.
If your integration user requires OAuth authentication (supported only in cloud environments), you must configure the user through Primavera Administration and submit a Service Request (SR). For more information, see the Primavera Administration Identity Management Configuration Guide.
Administrators can use the Integration Users sub-node (under the User Administration node) to view integration users, create integration users, and assign or edit permissions for Document Manager and access protocol (Legacy).
If you switch from Basic authentication to OAuth authentication (see Setting Up Integration Users with OAuth Authentication), existing Basic authentication users are set to inactive. You must create new users for OAuth authentication in the User Administration window of Primavera AdministrationTo access the Integration Users sub-node:
- Go to the Company Workspace tab, and switch to Admin mode.
- In the left Navigator, select User Administration, and then select Integration Users.
The Integration Users log contains the following elements:
Toolbar options
- Create
- Refresh
- Find on Page
Columns
- First Name
- Last Name
- User Name
- Status
- Description
- Auth Type
- Timezone
To view details for a specific user, select the user in the log, select the gear menu (
), and select Open.
The following explains each element in detail.
