Keyboard Navigation
You can use your computer keyboard to navigate through the application. Use the following keyboard shortcuts to access frequently used or important functionality. Note that keyboard shortcuts may change depending on your selected browser, and disabled buttons/fields are skipped.
Common Shortcuts
Action Windows Shortcut Key Mac Shortcut Key
Move right through elements in a log/page (right pane) Press Tab Press Tab
Move left through the elements in a log/page (right pane) Press Shift+Tab Press Shift+Tab
Select a current focus element Press Spacebar or Enter Press Spacebar or Enter
Content Log
Scroll through filter values and select/deselect a filter value from the list Press Tab, and then press Spacebar
Select a row in the Content log
Select the Usage Log of a content item
Select the Audit Log of a content item
