17 Queries
You will be using queries to extract data from the database for reports and data pickers and to set up auto-creation with creator elements.
A query is a data mining tool—a method for retrieving information from a database. A query filters the information returned from the database according to restrictions or conditions you specify. Unifier queries can:
- Filter or narrow the data being retrieved for use in reports and manager sheets.
- Set up conditions or triggers to make something happen automatically.
- Filter or narrow the data being retrieved for use in a data picker element.
