Remove Content Items From Visualizations in Projects/Shells
You can remove content items from the visualization layout as needed.
To remove content items from visualizations in a project/shell (Admin mode):
- Sign in to Unifier with project/shell administration credentials.
- Go to the specific project/shell tab, and switch to Admin mode. For example, select a tab called Vision Corporation.
- In the left Navigator, select Setup, and then select Visualizations.
- In the Visualizations log (right pane), select a visualization, and select Edit.
- On the Edit page, select a content item in the visualization layout, and select Remove (
