Running a Report
To run the Oracle Analytics Server Report in Unifier:
- Sign in to Unifier.
- Go to the applicable project/shell tab, and switch to User mode.
- In the left Navigator, select Reports, select Custom, and then select the applicable report node.
- On the [Report] page, select the Template and Format, enter the Search Parameters and any Additional Parameters, and select Run Report.
