11 Self-Service Portal
The Self-Service Portal enables users to sign in and work with specifically-enabled business processes. For example, Oracle Primavera customers use Unifier for corrective work order management. These work requests are usually generated from project participants who do not use Unifier. These participants can use the Self-Service Portal, which allows request submittals through a web-based tool. Users can use the Self-Service Portal to submit requests, to view the status of these requests, and to collaborate on submitted requests.
In uDesigner, you can enable certain business processes to be accessed through the Self-Service Portal. The business processes that you can enable to be accessed through the Self-Service Portal must have the following characteristics:
  • Simple
  • Company level
  • Non-workflow
  • Multi-record
The actions users can take through the Self-Service Portal are:
  • Create a business process
  • Modify a business process
  • Add or remove business process attachments
  • Add General Comments to a business process
Before you begin, design the Landing Page in terms of the text and graphics that you want it to contain. Then:
Step 1: Set Landing Page permission.
Step 2: Configure and activate the Landing Page.
Step 3: Specify users that receive portal-specific notifications. For more information, see Setting Up Non-Workflow Business Processes.
Setting Up a Self-Service Portal Landing Page
You must have Configure permission to be able to configure a Portal Landing page.
To set Landing Page permissions:
  1. Go to the Company Workspace tab, and switch to Admin mode.
  2. In the left Navigator, select User Administration, and then select Access Control.
  3. In the right pane, expand Administration Mode Access, expand configuration, expand All, and then select Landing Page.
  4. Set the permission as needed: Configure: Administrators can configure Self-Service Portal Landing Pages.
Configuring and Activating a Portal Landing page
If you have the Configure permission for the Self-Service Portal Landing Page, you can use an HTML editor to set up a Landing Page. After you configure and activate the Portal Landing Page, users signing in to the Self-Service Portal will see this landing page. You can configure one Landing Page and activate this page for use.
If the Landing Page is not configured, the user who signs in to the Self-Service Portal will see the Announcements page.
To configure and activate a Portal Landing page:
  2. In the left Navigator, select Configuration, and then select Landing Page.
  3. Select New.
  4. Enter the Setup Name and an optional Description of the page.
    The default initial status of the page is Inactive. You can change this status after you complete the page.
  5. Select the Layout tab.
  6. Use the HTML editor to add text and perform other editing functions.
  7. Select Insert Image "" to insert an image into your Landing Page. Browse for the image, and select OK and Close after the upload is complete.
  8. Select OK.
To activate a Portal Landing page:
  3. Select the Landing Page in the log.
  4. From the toolbar, select Status, and then select Active. You can inactivate the Landing Page by selecting Status, and then selecting Inactive. When a Landing Page is inactive, the user who signs in the Self-Service Portal sees the Unifier Announcements page. If no active Landing Page is set up, the portal user sees a default Landing Page.
