49 Setting Up the Earned Value Management Permissions
If you have access to the Earned Value Manager (EVM) feature, you can assign Earned Value Management permissions in the following permissions-related modules:
  • Permission Templates under Standards & Libraries
  • Access Control, and Users / Groups under User Administration
Permissions correspond to the:
  • Activity Manager and it sub-nodes
  • Earned Value Analysis in shell (User mode)
  • Master Rate Sheet in the Company Workspace (User mode).
In addition, configuration permissions are required to set up integrations from Oracle Integration, or from Gateway to set up the synchronizations at the Company Workspace (Admin mode) level.
Assumptions
Permissions for other related areas (Exchange Rates under Standards & Libraries) are granted at the Company Workspace (Admin mode) level, and permissions to modify properties of the shell types under Company Sponsored Shells are also given.
The Permission Settings values for the Earned Value Analysis Report (EVA Report) are:
  • Full Access
  • Create
  • View
  • View and Run
