9 Shell Landing Page (Admin)
After you create a shell, it is available for use.
To access your shell landing page:
- Select the shell tab to open it.
- Switch to Admin mode.
- In the left Navigator, select your shell name on top.
The top section of the landing page contains the Shell Dashboard.
By default, the shell dashboard contains the following blocks:
- Tasks
- Notifications
- Image
- Details
- Links
By default, the following two tabs are displayed.
- Summary
- Workspaces
You can change the layout of the tabs in My Dashboard.
Example
Block Length: 2 units
Block Height: 2 units
The following explains the various informational blocks in the Summary tab:
- Tasks
This block lists the total number of tasks belonging to the shell. In User mode, when you select Tasks, you go directly to the Task log.
- Notifications
This block lists the total number of notifications belonging to the shell. In User mode, when you select Notifications, you go directly to the Notifications log.
- Mail
This block lists the total number of e-mails belonging to the shell. In User mode, when you select Mail, you go directly to the Inbox log.
Accessing the Tasks, Notifications, and Inbox logs by selecting their respective tabs is not supported in Admin mode. - Image
This block displays an image, if available; otherwise, the block will be blank.
- Details
This block is displayed with either custom fields or default fields based on the configuration of the details block that is designed in uDesigner, shell manager. In the latest version, the shell home landing page displays the custom fields; otherwise, the shell home landing page only displays the default fields.
You can edit the details block by selecting My Dashboard, selecting Edit Dashboard, and selecting Edit
in the block. This capability applies to block information, or to the fields that must be displayed in the block.
- Links
If links have been added to the shell details, those links are displayed in this block.
Important Information
The Tasks, Notification, and Mail are grouped together in a standard block called "Items Requiring your Attention" that can be added or removed. Individual tiles cannot be added or removed.
You can add this block by selecting Add Block
, selecting Standard, and selecting Data Type as "Items Requiring Your Attention." When you save the Standard Block, the block will be added automatically to the dashboard.
The following explains the various informational blocks in the Workspaces tab:
The Workspaces tab is only available when geo-code server details are configured in Unifier.
- If there is no geo-location present in the sub-shells, Unifier displays a map without location markers.
- If there is a geo-location present in the sub-shells, Unifier displays a map with location markers.
When you hover over the location markers on the map, you can see the details for the location marker based on available information.
When you right-click the location marker, you can open the shell (for that location) in a new tab.
The left pane of the workspaces tab displays a log of all sub-shells that have been created under the currently selected shell. You can access sub-shell dashboards by selecting the gear menu (
) and selecting Open. If you would like to navigate backwards to parent shells, you can use the breadcrumb links listed above the Workspaces tab.
The user-created dashboards support all the existing functionalities, except the sub-shell log.
You can show or hide this tab in the Edit Dashboard window.
You cannot delete the Workspaces tab in any Dashboard.
My Dashboard (
) enables you to:
- Access additional dashboards for the shell, if available.
- Edit Dashboard
To open the editing mode of the current dashboard.
- Details
To view the shell details, as overlay. The details include Shell Name, Shell Number, and the following tabs:
- General
- Currency
- Options
- Images
- Links
- Calendar
- Custom Print Template
- Gateway Integration: Displays projects set up with Gateway as the default integration engine.
- Integration: Displays projects set up with Oracle Integration as the default integration engine.
- Print
To print the information on this page.
- Audit Log
To open the Audit Log as an overlay.
The Workspaces tab Sub-shell log has the following toolbar options:
- View
For example, Buildings, Land, Projects, Regions.
- Group By
Select, Hierarchy.
- Actions
- Get Activity Sheet Data
All Shells
Selected Shells
Filtered Shells
History
- Send Activity Sheet Data
All Shells
Selected Shells
Filtered Shells
History
- Search
- Find on page
- Expand All Groups
The columns displayed in the sub-shell log listed on the Workspaces tab are dynamically generated based on the fields defined in the Shell Manager Standard Log for the selected shell type in uDesigner with the exception that the first column always displays the Shell Name. To prevent redundancy, if a Shell Name field is also configured in the Standard Log, it is excluded from the dynamic column set because it is presented as the first column by default.
- Name
- Shell Number
- Shell Name
- Description
- Status
- Administrator
- Location
- User-Defined Text
The right pane displays the map that shows the regions.
