20 uDesigner Overview
uDesigner is a functional module of Unifier and is enabled automatically when the system is installed. When your Test or Development environment is first provisioned, a Base Configuration Package is installed. This package contains the essential attribute forms, a single-instance shell, and a multi-instance shell, which creates a basic framework that you can use to build your own customized configurations.
The uDesigner module is used to create:
  • Business Processes (BP)
  • Managers (such as Asset, Cost, Document, Planning, Portfolio, Space, Shell, and so on)
  • Configurable Modules
  • Attribute Forms (Users, Shells, Document Manager, Cost)
Collapse by Default Option in Block Properties
In the Block Properties window of both a BP form and a manager attribute form, there is a Collapse by Default checkbox. If the checkbox is selected, the block is collapsed by default. If the checkbox is deselected, the block is expanded by default.
With the Collapse by Default option, you can avoid scrolling through irrelevant information.
Under the Collapse by Default checkbox, the following note is displayed: “The block will be collapsed in User mode, only if the block has a label and the Show Border and Show Label options are checked. This option is applicable only for Standard View of forms.”
Collapse by Default is applicable to the following forms: Action form, View form, Detail form, and various attribute forms.
Additional uDesigner Options
You can use the uDesigner module to:
  • Create a design in the Development environment.
  • Configure, set up, and test your designs in both the Development environment and Test environment.
After this point you can import your designs to the Production environment by way of Configuration Package.
Oracle recommends that you:
  • Create your Configuration Package in the Development environment and import your Configuration Package to the Test environment for additional testing.
  • Import your Configuration Package from the Development environment onto the Production environment for use.
You can select the Unifier environment in the Unifier Configurator.
  • The Development environment is a server deployed by selecting the server type as "Development" in the Unifier Configurator.
  • The Test environment is a server deployed by selecting the server type as "Test" in the Unifier Configurator.
  • The Production environment is a server deployed by selecting the server type as "Production" in the Unifier Configurator.
The Development/Test environment is an environment that replicates the Unifier Production environment.
An object (for example a BP) can be deployed multiple times only in the Development environment.
The uDesigner functionalities are available in both the Development and the Test environments. The uDesigner functionalities are not available in the Production environment. The design changes made in the Test environment can be sent to the Development environment where you can prepare and publish the configuration package. The design changes made in the Test environment cannot be sent to the Production environment.
In the Test environment, you can import an unpublished Configuration Package.
In the Test environment, you cannot publish your Configuration Package.
You can only publish your Configuration Package from the Development environment.
The Test server is equipped with usable uDesigner and Data Structure Setup nodes so users can create or modify BP designs and include them in configuration packages and export them to another Test or Development server.
When deploying your designs, it is important to note the version numbers:
  • A deployed version indicates that the design has been tested in the Development/Test environment.
  • A published version indicates that the design has been included in a published configuration package intended for import in a Production environment.
