32 Unifier Mobile Application
The Unifier Mobile Application is built specifically for installation and use on mobile devices that use iOS or Android operating systems. To get the mobile app, you have the following options:
- Download it from the App Store or Play Store, or
- Launch Unifier, select your user name in the upper-right corner, select Get Unifier Mobile App, and follow the prompts.
After download, you can scan the QR code to set up the Server URL and user name on your Unifier Mobile App.
- If you are in a region without access to the Google Play Store, Apple App Store, or your organization is using a Content Security Service or Mobile Device Management solution and requires that users do not download from the Apple Store or Play Store, submit a Service Request in My Oracle Support to request versions of the Unifier Mobile Application for those scenarios.
- If your iOS device does not have the Passcode feature enabled, you can download and install the mobile application; however, the system displays a message that indicates you must go to Settings and enable the Passcode feature before you can use the application.
- If your iOS device is jailbroken (lacks the manufacturer's restriction that prevents installation of unauthorized software), you can download and install the mobile application; however, the system displays a message that you cannot use it with a jailbroken device.
- You must have permission to access the Unifier Mobile App. If you receive a message that indicates you do not have permission, contact your Company Administrator.
Important sign-in information for on-premises users on non-SSO servers
For on-premises customers on non-SSO server (prior to 19.12.2):
Unifier Mobile App uses the Basic Authentication for login while connecting to the Unifier web application deployed on a non-SSO server.
For on-premises customers on non-SSO server (on or after 19.12.2):
Unifier Mobile App uses Form-based Authentication while connecting to the Unifier web application deployed on a non-SSO server. As a result, you must use the latest version of the mobile app to access data on your device.
The user preferences, in the Unifier web application, will be effective when you sign in to the mobile app.
