25 Using the BP Visualizer to View Business Processes
Most organizations use a significant number of business processes (BPs) to facilitate business logic within Unifier. In addition to looking at a BP in uDesigner, which is where they are created and modified, you can use the BP Visualizer to see how a BP is set up. You can use the BP Visualizer to view information about BPs deployed in an environment and detailed information about each one, including their statuses, forms, logs, workflows, references, integrations, data elements (DEs), data definitions (DDs), and general information. You can view the cross-references between BPs and various objects, such as DEs. You can also use the BP Visualizer to compare different versions of a BP to examine the changes that have been made to it, which might be useful if you are responsible for determining whether a new version is ready for deployment or for identifying a change that caused a BP to stop working in the expected manner.
To access BP Visualizer node, you must have the View permission, which can be granted by an administrator.
To set the View permission:
  1. Go to the Company Workspace tab, and switch to Admin mode.
  2. In the left Navigator, select User Administration, and then select Access Control.
  3. In the right pane, expand Administration Mode Access, expand System Information, and select BP Visualizer.
  4. In the Module Permission Settings window, select Add.
  5. In the Permissions Setting for <selected item> dialog box, select Add Users/Groups.
  6. In the Users/Groups window, select the intended users or groups, and select Add.
  7. To return to the Permissions Settings for <selected item> dialog box, select OK.
  8. In the Select Users/Group section of the window, select the users or groups, and then select the View level of access for the user or group in the Permissions Settings section.
  9. To save your selections and return to the Module Permission Settings window, select OK.
  10. Select Apply to save changes and keep the window open, or select OK to save changes and close the window.
To access the BP Visualizer:
  2. In the left Navigator, select System Information, and then select BP Visualizer.
    The Business Process list is displayed.
    You can scroll through the list of BPs, use the up and down arrows next to the headings to sort information in an ascending or descending order, or use the Filter option to refine the display (see Filtering the List in the BP Visualizer). You can select any BP in the list to see detailed information about it, such as forms, logs, and workflows.
The BP Visualizer log includes information for each BP ranging from the ID and name through the date that it was created and the date on which it was last modified. After you select a BP, the page for that BP provides the following tabs:
Tab Description
General Provides high-level information about the BP, such as the ID, Name, Version, and Type.
Statuses Identifies the statuses available for the BP, such as Completed, and indicates whether the status is a Terminal one.
Forms Lists the forms that are part of the BP, such as Upper, Detail, and View, and provides access to details about each form.
Logs Indicates the logs that are updated as part of the BP and provides access to details about each log.
Workflows Lists the workflows that the BP can follow and lets you view the workflow itself. For non-workflow BPs, this tab is empty.
References Lists the cross-references that might involve the BP, ranging from a BP that might result in the automatic creation of the selected BP to all the pickers, data elements (DEs), and attributes.
Integrations Provides data integration information, such as the labels and DEs, and indicates whether data flows in one direction or both.
Data Elements Provides detailed information about each DE used in the BP.
Data Definitions Provides detailed information about each data definition (DD) used in the BP.
Compare Versions Lets you compare any two versions of the BP and view all changes or filter to show only information that was changed, added, or removed.
