View and Export the Visualizations Audit Log From Projects/Shells
The Audit Log displays a chronological list of actions performed on visualizations by all users/groups in the Visualizations log of a project/shell. Project/Shell Administrators can view or download the audit log.
You must have Modify or Manage permissions enabled for visualizations in the specific project/shell to perform this task.
To view and download the audit log of visualizations from a project/shell:
  1. Sign in to Unifier with project/shell administration credentials.
  2. Go to the specific project/shell tab, and switch to Admin mode. For example, select a tab called Vision Corporation.
  3. In the left Navigator, select Setup, and then select Visualizations.
  4. In the Visualizations log (right pane), from the Action menu, select Audit Log.
    • Modified: Date and time each change was made in the data source. The date and time format is based on the user's preferences.
    • Action: Type of change made to visualizations, such as, Created, Added, Removed, Updated, Duplicate, and so on.
    • Modified By: Name of the user who made the change in the data source.
  5. To view the displayed column information in the ascending or descending order, select Sort By.
  6. To download the audit log as a Microsoft Excel spreadsheet, select Export ("") .
