22 Working with Integrations
The Integrations grouping node lets you configure third-party application integrations and set up notifications that are triggered by steps within business processes (BPs).
  • If you are integrating Unifier with Acrobat Sign or DocuSign, see Selecting and Configuring a Default System for E-Signatures and see the Unifier Adobe Sign Configuration Guide or Unifier DocuSign Configuration Guide.
  • If you are using Bluebeam with your environment, see the Unifier Bluebeam User Guide.
  • For more information about Event Notifications, see Event Notifications.
  • For more information about other applications, such as Primavera Analytics, Primavera P6, Primavera Gateway, Oracle Primavera Cloud, and Oracle Integration, see Unifier and Other Oracle Applications.
