4 Integrations and 3rd Party Applications
This document covers the client system requirements for Unifier cloud deployments.
Category Product Version Exceptions and Additional Information
Microsoft Office Microsoft Excel 2016
(Required) Used to create XLSX files.
Schedule Developer & Schedule Management
Microsoft Project Standard 2016, 2021, 2024
Used to create a schedule file, which can be imported into a schedule sheet and an activity sheet.
Note The Schedule Manager feature was deprecated starting with version 23.5. Starting with version 25.10, the feature no longer supports the creation of Schedule Attribute forms, Schedule Resource Attribute forms, and Schedule Sheets. To ensure that existing customers can continue to view and update existing information, some functionality with existing forms and sheets is retained. For example, you can continue to use templates to update existing projects and shells, however, you cannot create a new project or shell that contains Schedule Sheets, even if the template contains an existing Schedule Sheet. Additionally, the Create permission for Schedule Sheets is automatically changed to Modify after you install version 25.10.
